Custom Toolbars
Custom Toolbars
Does anyone know if there is a way to put NX toolbars inside of a custom toolbar (without the need of moving item by item) for example:
i create a toolbar called 2D and inside of my 2D toolbar i want "Lines and Curves" "Drawing" and "Dimension" toolbars/items from nx defaults.
is there a "easy" way to do it ?
NX8.5 - NX9 User
RE: Custom Toolbars
I see that you're also using NX 9.0. Are you really concerned about TOOLBAR customization in light of the fact that NX 9.0 uses a Ribbon-style interface?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
RE: Custom Toolbars
i think we can call it merge 2 toolbars into one, yes.
NX8.5 - NX9 User
RE: Custom Toolbars
As for customizing toolbars, if you don't want to do it using the interactive 'Customize' tools, you can always edit the actual .tbr files which would allow you to 'Cut & Paste' from one .tbr file to another. Once you've got your edited .tbr file (don't change the name of the file(s)), simply place them in the 'Application' folder in your UGII_USER_DIR= folder (note that this procedure will also work when you start to customize your .rtb files).
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
