Drawbacks of 431 with up to 46 RC hardness?
I work at a commercial heat treater. We have a customer who is considering using 431 material in pipes for oil field service (I'm not sure exactly what goes through the pipes). It would be tempered below 700° to ensure meeting their Charpy minimums. After hardening and tempering, the hardness would be 43-46 HRC (based on samples we have run).
Their engineer is concerned about having a product with hardness about 40 HRC, but wasn't able to articulate a particular reason. I believe he's thinking of something like stress-corrosion cracking, which I know a material such as 4140 is much more susceptible to at hardnesses above 40 HRC. Does 431 material have this same vulnerability at higher hardnesses?
RE: Drawbacks of 431 with up to 46 RC hardness?
why not hardening at higher temperature, say 1900F, then temper at 700F? This will give you the best of Charpy, and lower HRC as well.
Or, if the high hardness is a big concern, you may use a high temper temperature (>1100F) to get a low hardness, and at the same time still good impact strength.
Avoid tempering between 700-1050F which gives you low impact and decreased general corrosion resistance, although it tends to give you high tension properties.
We also tested tempering at 1100 degrees. A portion of this part gets carburized and that temper dropped the hardness in the carburized area too low.
Thank you for the advice on SCC.
The reason is that higher hardening temp can lead to remaining austenite after quenching, which will decrease hardness, while increase toughness.
Oil quench (high volume of well agitated oil) from 1800 for better toughness.
Temper at 1100 is too soft??? This is still 150ksi UTS.
If he wants to use it harder than that then he will have to accept the low toughness and high risk of SCC.
This alloy is susceptible to SCC from both hydrogen and caustics. The hydrogen could be present because of corrosion.
Can you provide additional details of the carburizing process you used with this 431 stainless?
The plan for this application is to paint carburizing stop-off paint over most of the pipe, since the carbides on the carburized surfaces will significantly decrease corrosion resistance. (I know some heat treaters are able to carburize stainless steel without producing carbides, and I did some tests with this goal in mind. My conclusion is their equipment is capable of carburizing at higher temperatures - probably around 1900-2000°F - compared to my furnaces that have a maximum of 1800°F.)
Then the parts with unpainted bearing races (which are sealed from the corrosive media) would be carburized on basically a very long but otherwise standard carburizing cycle (long cycle due to the chromium and nickel slowing down carbon diffusion).
I really appreciate all the feedback on the SCC susceptibility, our customer was not very clear on this and I hadn't worked with stainless enough to be confident in that myself. We have suspended our testing with 431 material and are currently pursuing testing with a different stainless alloy.
If you carburize at higher temp you still form a lot of carbides, but you get enough Cr diffusion so that you don't have a Cr depleted region around them. You loose some corrosion resistance due to lower Cr in solution, but you are not sensitized.
