NACE - ISO 15156 - VERSION 3 - 2015
Hi All,
Many thanks for the help in advance. Truely appreciate all the reply.
My question here goes:
Since the latest version of ISO 15156 (Petroleum and Natural Gas Industries - Materials for use in H2S containing environments in oil and gas production), 3rd edition, has been released, I am wondering what about the NACE MR0175? though I understand both documents have the same informations and details.
Will it release sooner or everything has sticked to the ISO standard?
Thank you,
Jeffrey
Thank you,
Jeffrey
RE: NACE - ISO 15156 - VERSION 3 - 2015
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
Sorry if I ask questions which may or may not be related to the thread.
1. Based on the IHS standards expert, it has appeared to me that the individual document of the NACE MR0175 (part 1,2,3 ) has been withdrawn but not the full document. Do you have any idea on this? Many apologies if I ask the wrong questions.
2. To my understanding, NACE MR0175 has the same contents as ISO 15156. So what is the major differences having 1 ISO standard and 1 NACE MR0175? Is it mainly due to ANSI requirements?
3. On the other hand, API 6A also shared similar contents with ISO 10423. However, API 6A has released the 20th edition while ISO 10423 is only on the 4th edition. I am wondering why there is a huge difference between both versions. I always thought that ISO should always be updated with API 6A or perhaps maybe extend to MR0175.
Thank you,
Jeffrey
Not quite true, particularly with respect to SSC domains, and it also added HIC too. Now, the only difference is that the ISO tends to get published first whilst NACE goes through its balloting process and gets published later. There has been no technical difference between the two for a while; hopefully, this NACE ballot won't throw a spanner in the works.
@Jeffrey
1.
Have a look at document number 12 of 12 in your IHS search results: IHS have lumped everything under one document number and they still show the 2009 version as active along with all the circulars.
2.
There is no difference between the two.
3.
Do not follow the question. API Spec 6A shows it to be ISO 10423 (Modified) on the front cover. The modification is usually only the addition of a US Annex to change back everything that the US didn't like in the ISO and couldn't get voted out during the ISO approval process - see Annex O.
Steve Jones
Standards in the US must be voted on by a consensus of users and producers. The US government does not generate standards (not even MIL any longer).
Steve Jones
But try joining an ISO committee, they are not 'open' or 'consensus' as AISI defines it and as we think of it.
I have never been on an ASTM, AMS, or NACE committee that was all US, country of origin doesn't matter.
Yes, the EN is really what I meant to say.
Can anyone summarize the major changes in the new edition of ISO 15156?
Thank you. I have to admit that I have learned and benefited a lot from both advises and professionals help given.
Hi jmec87,
You can check the foreword from individual document. The changes are stated there.
With regards to when it will be completed, I have no idea. I will keep a lookup.
Jeffrey
