Save As - Part Files for Part Numbering
I am working on a macro to rename all of the parts in an assembly. I have gotten all of the "Part Numbers" to update to the new numbers but am having a hard time saving "Save As" all of the files so that the file has the same name as the part number. I started by trying to save at the same time as I changed the part number but it seems very difficult to jump between products and their respective document to be able to save. I therefore went the route shown below of just saving all of the documents by recursively scrolling though the tree and saving any parts. It still isn't working though. Any suggestions?
Sub SaveParts(oInDocuments As Documents, oInPart As PartDocument, ByVal bLevel As Integer, DocPath As String)
bLevel = bLevel + 1
Dim oInst As Documents
Set oInst = oInDocuments
Dim PartDoc As PartDocument
Set PartDoc = oInPart
'No components --> CATPart
If oInst.Count = 0 Then
oInPart.SaveAs (DocPath & "\" & PartDoc.Part.Name & ".CATPart")
Exit Sub
End If
'Multiple components --> CATProduct
Dim i As Integer
For i = 1 To oInst.Count
Dim partType As String
partType = oInst.Item(i).Name
partType = Right(partType, 2)
If partType = "rt" Then
Dim Part2 As PartDocument
Set Part2 = oInst.Item(i)
Else
Dim nInst As Documents
Set nInst = oInst.Item(i)
End If
Call SaveParts(nInst, Part2, bLevel, DocPath)
Next
End Sub
bLevel = bLevel + 1
Exit Sub
End If
Dim i As Integer
Else
End If
Next
End Sub
RE: Save As - Part Files for Part Numbering
do you know about typename(object)? should work for part / partdocument / product / productdocument...
I made several recursive for the almost same reason as you.
when i 'recurse' I give only one object, in my case i save all in the same folder.
if it's a partdoc then i save it, if it's a productdoc then i recurse its products (child elements) one by one. Then I save it.
That should do.
when you say it does not work, what is the result you have, if any?
Dim oDocs As Documents
Set oDocs = CATIA.Documents
Dim docPath As String
docPath = oDocs.Item(1).Path
Dim changePath As Integer
changePath = MsgBox("Current save location is: " & docPath & " Would you like to change file path?", vbYesNo)
If changePath = vbYes Then
docPath = InputBox("Enter new file path (eg. T:\_PROGRAMS\COMMERCIAL\_DATA\will.eagan\A330):", "File path")
End If
Dim v As Integer
For v = 1 To oDocs.Count
If TypeName(oDocs.Item(v)) = "PartDocument" Then
Dim oDoc2 As PartDocument
Set oDoc2 = oDocs.Item(v)
Dim oPart1 As Product
Set oPart1 = oDoc2.Product
oDoc2.SaveAs docPath & "\" & oPart1.PartNumber & ".CATPart"
End If
Next 'v
Dim x As Integer
For x = 1 To oDocs.Count
If TypeName(oDocs.Item(x)) = "ProductDocument" Then
Dim oDoc1 As ProductDocument
Set oDoc1 = oDocs.Item(x)
Dim oProduct1 As Product
Set oProduct1 = oDoc1.Product
oDoc1.SaveAs docPath & "\" & oProduct1.PartNumber & ".CATProduct"
End If
Next 'x
