Feature Datums are showing up in Drafting View NX10
We use Feature Datum’s in are references to help constraint assembles and layer them out at the drafting level (so you will not see them in the view). In NX10 some of the Datum’s are showing up in the Drafting views and if you do info object on the Datum’s it shows the layer that I have turned off in the view.
Does anyone know why layering does not work anymore or how to hide Feature Datum’s in the view without using the hide command or removing them from the Reference Set?
