Primer on Studded Joists
Received an RFI asking if it is okay to have primer on joists that are to have studs. Concern is that the primer will be where the studs are shot through decking due to the joists being dipped and will interfere with stud connection. Is dipping the joists in primer acceptable?
RE: Primer on Studded Joists
I assumed that the questions concerns welding shear studs to open web steel joists (bar joists). AWS D1.1 includes studs welded with a gun. Also see SJI's Standard Specifications for Composite Steel Joists https://steeljoist.org/product-category/publicatio...
