Any standards for measuring emissivity and reflectance?
Can anyone point me to specs and/or devices that cover the measurement of the optical properties of emissivity and solar reflectance of surfaces?
Thanks for anything you can suggest!
Tunalover
Tunalover
RE: Any standards for measuring emissivity and reflectance?
For Solar Reflectance you can use either ASTM E903 or ASTM E1918. E903 is good for any roof type unless it is variegated. E1918 is used for variegated roofing products.
For testing Infrared Emittance you can use either ASTM C1371 or ASTM E408.
Dan Walker
dwalker@mbma.com
Actually I'm looking for a test method that can be used for ANY material, not just roofing. Is there anything about ASTM E903, ASTM E1918, ASTM C1371, and ASTM E408 that precludes their use on materials other than roofing? My application is the design of outdoor electronic equipment.
Bruce
Go to the ASTM website and review the abstract info available for each standard. I am attaching the link to ASTM E 903, which is not specific to roofing material:
http://www.astm.org/cgi-bin/SoftCart.exe/STORE/filtrexx40.cgi?U+mystore+hjlz1316+-L+E903+/usr6/htdocs/astm.org/DATABASE.CART/PAGES/E903.htm
Thanks for the link. I saved it and will pursue this further.
Bruce
