when does the pressure vessel fill with nitrogen?
Hi
I have a question : when do we fill the vessel with nitrogen?
I'm looking for a spec or standard that help me .
RE: when does the pressure vessel fill with nitrogen?
Very vague question so a rather vague answer
Please give more details.
r6155
Couldn't help myself- the question is so totally vague to be of absolutely no help to anyone including the OP...
To be slightly serious kangar - Nitrogen inerted vessels kill people on a yearly basis when they enter them without realising it as there is no smell or odour, just a very serious lack of oxygen.
r6155
I know two other reasons when Nitrogen is used in a system:
1. I've seen thermal oil systems expansion tank with Nitogen "blanket". This is done in order to avoid oxidation of oil because of high temperatures.
2. Another example I have seen Nitrogen is used for emergency instrument air supply in case if compressors are down. Nitrogen was stored under pressure in liquid form in a tank.
Curtis
