Code case for SA516 Gr.70 plate produced before year 2013
Hi All
My project have numbers of pressure vessels which designed to ASME VIII div.1 Edd.2013; initial specification does not call for ASME stamp however end user has recently requested ASME stamp at middle of the fabrication process.
When ASME stamp is to be applied, the materials are to be complied with ASME Ed 2013 and plate SA 516 Gr.70 Edd 2013 has a requirement that Boron content shall be limited at 1% (I do not have standard with me here to confirm) and also reported in mill certificate. However some of our plates made before 2012 and its mill certificate do not have Boron content. Due to this we will have to do chemical analysis on these plate to identify Boron content.
I am thinking of the worse scenario when Boron content exceeds the limit, what could be the code case allowing me to use these materials? Pls share your knowledge and opinion on this case?
Thanks and appreciate your helps
MIKE
MIKE
RE: Code case for SA516 Gr.70 plate produced before year 2013
Your post is confusing in the sense that once fabrication is in process it is not that simple to stamp the vessels unless the AI has been involved up until this point. You better check again the with stamp holder regarding your concerns.
Boron requirement of max. 0.0010% by heat analysis is set by SA20 ed.2013 which will be a mandatory reference for SA516.
r6155
