tolerance for patterned holes
hi all,
I'm designing a part that has 20 holes in it in a 15 mm distance from the datum A (see in attached picture) , whats important to me is that all the holes centers will be on the same plane within 0.01mm , i dont want to place a +-0.01mm tolerance on the 15 dimension because its not important , the holes can be even 16 or 14 mm away from the base but whats important is that the centers will be on the same plane , what is the correct way to write that on the drawing?
thanks
RE: tolerance for patterned holes
idanbrk,
Select two holes, and make them your secondary datum B and tertiary datum C. Put a sloppy profile all around your 210x30mm outline.
JHG
I would use a width datum as the primary datum.
Tunalover
Composite, the way Vishal described it
thanks everyone , you have been very helpful
