tube feature single or multiple segments?
Hello all,
I have a question about the Tube feature. In the settings of this feature you have the option single or multiple segments.
I see the visual difference between the two options is the number of faces. But is there also some difference in the back ground or what is the advantage of use single or multiple segment.
Some times when I created a tube with multiple segments I get a problem in drafting that NX can't make the updates of the view (mostly of an assembly where the tube is in assembled)
So there is in my opinion not only something happening in the number of faces but also something more.
how can help me with this?
thanks.
thanks.
RE: tube feature single or multiple segments?
In regards to stability, I have a coil spring modeled as a deformable part in which the tube feature sometimes (not always) fails when using a single segment tube.
When using the multi segment option NX will create a number of Torus faces / Cylinders along the path. A torus is a mathematically analytical shape, i.e there is no need to have / use a tolerance on the face itself, instead the modeling tolerance is used between the path and the torus centerline. ( Since the centerline of a torus is a circle and nothing else.)
Using the single Segment option NX will create a single face B-surface . A B-surface uses the modeling distance tolerance. The resulting face will be within the modeling distance tolerance and not exact, thereby the problem with the blend.
regards,
Tomas
