Thermal
Thermal
We are extruding 10 ft. long flexible PVC tubing. When used to deliver solution during surgery, the solution loses some of it temperature (gets colder). Is there any material to coat the PVC tube to eliminate any heat temperature loss of the solution.
thanks
thanks
RE: Thermal
also the room temperature that they are operating in and grade of PVC you are using for the application.
RE: Thermal
RE: Thermal
I am interested to know how the colour of the tube effects the thermal properties and heat loss off the solution to the tube in reference to the solution and/or the ambient temperature. As far as i was aware the actual heat loss and how to reduce or improve this was dependant of the heat transfer coefficient of the materials, gases or liquids involved.
I understand that silver reflects light associated heat and black will absorb, but i am a little confused about its thermal thermal transfer. Would the silver masterbatch possibly draw more heat away from the solution as it is made up of metallic composites?
RE: Thermal
RE: Thermal
RE: Thermal
Can you co-extrude the pvc with a foamed layer.
pat
