Top and bottom slab thickness
RE: Top and bottom slab thickness
I got the answer,
this distance is used to report the design output (based on definition of pre-analysis). For instance, forces/stresses at specified distance in the either bottom slab/top slab can be viewed. Refer to Bridge Superstructure Design of CSiBridge Section 10.1.1 for more details.
Cheers
