How to link Abaqus subroutine (written in Fortran) to Matlab in every increment during running
I've modeled a process in ABAQUS and have wrote a subroutine for that. It is Ok and it runs. now i want to make some change in my model when the process is running by the use of matlab. for this purpose it is required to link fortran and matlab, I really appreciate any help.
RE: How to link Abaqus subroutine (written in Fortran) to Matlab in every increment during running
Are you new to this forum? If so, please read these FAQs:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
However, you will have to be careful i.e., you do not want to end up tweaking the model (while it is still converging to a solution - assuming an implicit run) in such a way that is becomes non-physical (by violating laws of physics). With Explicit, you may have to be even more careful.
it would be so helpful if I find an example like as my problem...
thank you
So, here is my suggestion (as a suggested strategic breakdown of the workflow):
Python scripting (no Abaqus) -> Python script + (1 element) Abaqus/CAE OR Python script + (1 element) ODB -> -> Same as previous with a little more complexity -> Reading in your ODB -> Reading in incremental values.
After struggling with documentation I've found that If I want to reach an output in a specific increment I have to refer to odb file,
So If I haven't any odb file I can't read any output till that time
I want to do this:
A=read S11
B=make a change in CAE if it is required
increment1>>>A>>>B>>>...continue...increment2>>>A>>>B>>>...continue...increment3>>>A>>>B>>>...
