Strongest solder for soldering copper to copper (vibration resistance)
Hello.
I have an alternator that I need to solder copper wire to the bridge rectifiers.
Now as this is being used in a vehicle, there will be vibration which may weaken the solder or cause it to fracture.
I need to know which solder will be able to give the strongest hold and be resistant to cracking under vibration,
What sort of combination of lead, tin and silver would be ideal?
Or would a solder that has no lead be a better option?
I have many different solders available at my supplier, so I want to select the one that would be best suited to this job.
Thanks.
Thanks.
RE: Strongest solder for soldering copper to copper (vibration resistance)
They just might have tests done, or experience with this. I believe (but don't quote me on this) in aviation, solder isn't allowed because of vibration fatigue. Maybe there are exceptions, or alternatives, or again test results in this field.
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
The key to preventing excessive stress at your solder joint is to provide proper clamping/strain relief of the wire close to the joint. The strain relief design should provide sufficient constraint of the wire to isolate the solder joint from dynamic forces acting on the wire length between. The strain relief should also provide enough compliance to prevent over-stressing of the solder connection from thermal expansion/contraction in the surrounding structures.
You can probably get a soldered wire connection to work well for your application if you pay attention to details and do a thorough job of designing the solder joint and component/wire attachments.
If you are soldering diodes in alternators, you need to look at the original solder to see what it is composed of.
The diodes in an alternator can get pretty hot at full load , sometimes requiring a silver brazing type solder, instead of a tin lead type solder. The last thing you need is a solder failure at full load.
That said, for flexibility, and resistance to cracking , a 50/50 tin lead solder would be better. Most electrical ( wiring joint.) solders are 60/40 tin lead for their sharp melting point and quick freeze. If you are forced to use lead free then 95/5 95% tin 5% silver is usually specified. There are other lead frees with bismuth and other alloys also available.
B.E.
You are judged not by what you know, but by what you can do.
