error
error
Hi Dears
I want to create a moment at a node but when did this, the job analysis aborted due to errors. the Error is:
"1 nodes have inactive dof on which boundary conditions are specified. The nodes have been identified in node set ErrNodeBCInactiveDof."
what can I do?
what can I do?
RE: error
RE: error
but waht should i do now ,should i change my element type ? which type works for this matter ?
also the area that i put moment , have rotational degree of freedom.
thanks
RE: error
RE: error
i will send you my CAE in attache.
RE: error
