Seismic R Value if column for two mterials
I was quite confused how to deal with the R value for my roofed footbridge. I have a cantilevered concrete column and had my flooring and roof frame by structural steel. I assume the upper part being steel has different seismic response than than the supporting concrete column. Do i need to use two mathematical models when i wish get my seismic forces each material part?
RE: Seismic R Value if column for two mterials
