Frick Screw Compressor Variable Vi
I have a compressor I'm having some issues with. It's a Frick oil flooded screw compressor in Ethane/Ethylene mixed refrigerant service. I actually have two of them running in parallel on the same system. These are variable Vi machines and while I'm familiar with how the variable Vi works and what its function is, these two have me stumped. My understanding is that the slide stop is used to match compressor discharge pressure as close to system discharge pressure as possible to prevent under/over compression. The thing that baffles me is that these machines don't even have pressure transducers to read system discharge pressure, only compressor discharge. On one of these compressors in particular, the slide stop appears to have a mind of its own. It will be running great and out of nowhere the Vi will drop from 5.0 to 2.2 and it causes extremely high discharge temps when it happens. I've tried troubleshooting it, but without knowing what exactly is controlling the slide stop and telling it where to go, I've hit a dead end. Is there someone out there that can shed some light on what might be going on?
RE: Frick Screw Compressor Variable Vi
Much is made of the inefficiencies caused by over compressing or under compressing. Here is a slide from my course that shows that over compression can cause a big reduction in efficiency, but under compression not so much.
If I was you, I'd figure out the optimum VI (Pdisch=Psuct*(VI)k), set the VI there lock it down, and remove any actuator that lets it (or forces it to) change. Make sure that the code in the PLC isn't trying to drive the VI (it probably is and you'll need a programmer to exorcise that function). In air conditioning service, variations in load are easily handled by the slide valve if the driver is not variable speed.
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. Galileo Galilei, Italian Physicist
With all that said, I could easily manually set the slide stop position and pull the fuse for the solenoid valve that runs it. Under most conditions, I think it would run fine like this and if I felt the need to make a change I could put the fuse back in and change it to what I need to change it to. I would just like to figure out why it seems to have a mind of its own and jump around for no apparent reason. The only thing I can think of is it's written in to the logic, but I don't see any kind of process parameters change that would cause it to make that adjustment.
The statement " these machines don't even have pressure transducers to read system discharge pressure, only compressor discharge." - is confusing.
David Simpson, PE
In principle, the control concept David has outlined would be preferable.
It does sound like you dont have a variable speed driver at the moment, hence your thought to disable the actuator that operates the slide valve. One interim measure (till a VFD is implemented, assuming this is not on split range control, no mechanical faults etc ) would be to enable low suction pressure recycle from the C2 / C2= condensor ? That may not be easy either. Running start / stop may ruin the driver / compressor shaft bearings.
George: From my understanding, a slide stop is used to essentially change the location of the discharge port within the compressor. It's done to be able to match the internal compressor discharge pressure to the discharge pressure of the rest of the system to prevent over or under compression. In order for the PLC to control the slide stop, I would assume that it needs a pressure transducer to read the internal compressor discharge (which it has) and one to read the system discharge pressure (which it does not have). Unless of course there's some sort of volume ratio code written in to the logic in the PLC, which it appears may be the case. Hopefully that clears up some of the confusion with my original statement.
Must say I dont know much about this slide stop, but perhaps it is required for startup operations when there is low external discharge pressure, and there isnt enough dp between internal discharge and external discharge to keep the lube oil recirculating? Hence the discharge slide stop moves to a choked position to create sufficient dp (to keep the lube oil running to all LO injection ports)?
So perhaps this slide stop is operating to maintain a predetermined fixed casing discharge pressure at the moment all the time, which is high enough to maintain or exceed this required dp even when the external discharge is at a presumed high pressure.
So perhaps the slide stop is going into this throttle position when it sees lower than set discharge pressure, which may be when the C2 / C2= condensor is at a lower condensing pressure?
Maybe a better way to operate the slide stop is to maintain a fixed DP between external discharge and internal casing discharge pressure as you suggest. Presume this slide stop can be continously varied in position rather than in large steps.
Putting this slide stop in a fixed position as you suggest now may work for high volumetric throughputs but not at lower throughputs ( at lower throughput, the choking effect at the slide stop would be less, and LO recirculation rate would be less)?.
This doesnt sound like a difficult problem - getting the Frick compressor vendor to work with you on this is half the work done already I'd think.
The other is the unloader which is called a "slide valve" on the Frick (and most process screws, it is either a turn valve or a poppet valve on air-derivative screws). The slide valve should be left under PLC control.
David Simpson, PE
