Drafting Wireframe Color
I am currently working with NX 9.0
Have not had these problems with other versions
of NX. I modeled a part. Created an associated
drawing. Wanted to add color to wireframe within
drawing. Do I "make work part", change color,
go back to drafting, and select "Wireframe color source"
Body? It is not working for me here.
Help.....
RE: Drafting Wireframe Color
In the drafting view settings, go to "visible lines" and click on the color box; this will bring up the color selection dialog, shift-click on the selected color to de-select it and press OK. The wireframe color in the drafting view for visible lines will now inherit the body color. Repeat for hidden lines, smooth edges, etc as required. Change these settings in your drafting preferences/template files/user defaults as necessary so the settings are used on future files and views.
www.nxjournaling.com
