Queston on translating Parasolids
I am trying to investigate Parasolid files a bit more. Currently when I receive outside data from a vendor that does not use NX, we request a Parasolid file of the assembly. Now I know of two ways to translate that Parasolid assembly file back into NX. One, File>Import>Parasolid, This is a No Good way because we loose the assembly structure and simply get a file with hundreds of dumb solid bodies. Two, File>Open>Parasolid, This was is Good when it comes to preserving the assembly structure but No Good when it comes to each component name. This NG condition is because every item gets __id1234_x_t added to the component name.
Does anyone have any idea if we can alter a setting in NX to not add the __id1234_x_t to every component name?
Currently our plan is to change to a step file of the assembly to both preserve the assembly structure as well as the component name. However I was asked to investigate if there is a way to improve the parasolid translation since others feel that it is a more accurate way of translating data from our vendors to NX.
Thank you,
Jaime
NX9 Native
Thank you,
Jaime
NX9 Native
RE: Queston on translating Parasolids
www.nxjournaling.com
