Journal to flip arrow placement on selected dimensions
Here is a journal I wrote that will flip the arrow placement of a dimension. I found it a little tedious to have to go under style and have to do it manually so I created this journal and created a short cut to it. Hope you find it helpful. Tested on NX8.5, but should work on all versions.
Design Engineer, NX 7.5
CODE --> .net
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module NXJournal
Sub Main (ByVal args() As String)
Dim theSession As Session = Session.GetSession()
Dim theUFSession As UFSession = UFSession.GetUFSession()
Dim theUI As UI = UI.GetUI()
Dim mpi(99) As Integer
Dim mpr(69) As Double
Dim radius_value As String = Nothing
Dim diameter_value As String = Nothing
Dim numObjects As Integer = theUI.SelectionManager.GetNumSelectedObjects()
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Edit Dimension")
For i As Integer = 0 To numObjects - 1
Dim nXObject1 As NXObject = theUI.SelectionManager.GetSelectedObject(i)
Try
theUFSession.Drf.AskObjectPreferences(nXObject1.Tag, mpi, mpr, _
radius_value, diameter_value)
If mpi(0) = 1 'Then Text/Arrow Placement is Automatic
mpi(0) = 3
ElseIf mpi(0) = 2 'Then Text/Arrow Placement is Manual, Arrows In
mpi(0) = 3
ElseIf mpi(0) = 3 ' Then Text/Arrow Placement is Manual, Arrows Out
mpi(0) = 2
End If
theUFSession.Drf.SetObjectPreferences(nXObject1.Tag, mpi, mpr, _
Catch eX As NXException
'Echo("The object you selected: " & vbNewLine & nXObject1.ToString & vbNewLine & vbNewLine & "Failed to change arrow placement. See below error for details:" & vbNewLine & eX.ToString)
End Try
Next
Dim nErrs1 As Integer
nErrs1 = theSession.UpdateManager.DoUpdate(markId1)
End Sub
Sub Echo(input As String)
Dim s As Session = Session.GetSession()
Dim lw As ListingWindow = s.ListingWindow
lw.Open()
lw.WriteLine(input)
End Sub
End Module Design Engineer, NX 7.5
RE: Journal to flip arrow placement on selected dimensions
See attached image.
Or, on an existing dimension, double click , then same as above.
Tomas
