NX 7.5 deformable part tutorial from learning adventage problem
Learning advantage, NX 7.5
+CAD - Foundation
+Assembly Modeling - Applications
+Deformable Components
Make a part deformable with a guide string.
Nice tutorial, it actually would solve my problem if I can find how to make the Tube(0) feature from "front_brake_line.prt" that is used in tutorial. So question is how to make Tube to use it as deformable part in NX 7.5?
PS. I need to make cable with one TeamCenter8 number, and to reuse it in same assembly, but in different positions.
RE: NX 7.5 deformable part tutorial from learning adventage problem
OK, so to make this clear, Tube feature from Learning advantage is different from normal Tube feature. Double click for edit of normal tube give usual guide/diameter/etc. dialog box, but when I double click on Tube feature from Learning advantage i got menu from picture attached.
That's just the old-style dialog boxes. I'd guess the learning advantage part was created pre-NX 5.
www.nxjournaling.com
Thank you!
