vessell over 3000 psi
Hi guys, i'm design a pressure vessel over 3000 psi, but i dont know... if i can combined div 1 and div 2..
because i calculated the thickness with div 1, but it's so higher..
RE: vessell over 3000 psi
The additional engineering and inspection requirements in Division 2 are there for a reason - because failure in a vessel that operates at 3000 psi will likely kill someone, as well as cause hundreds of millions of dollars of direct damage as well as significant amounts of consequential damage.
I understand.. so i choose one code for my desging.. but nozzle? welding? structure of the vessel i mean skirt, legs?
