what is the reason for two times screw compressor air cooler leakage ?
INGER SOLL RAND COMPANY AIR COOLED SCREW COMPRESSOR 2 TIMES AIR COOLER RAPTURE? (RADIATOR) SINCE 5 YEARS CONTINUOUSLY RUNNING THIS EQUIPMENT.
STARTING TIME OUTLET PRESSURE PERFECT BUT CONTINUOUS RUNNING TIME AIR LEAKAGE IN AIR COOLER. THIS IS SECOND TIME..WHAT IT IS THE REASON?
RE: what is the reason for two times screw compressor air cooler leakage ?
I am having trouble separating statements from questions from conjecture in your post. There is never a reason to type your whole post in CAPS, and people often see that as rude. If you are having trouble with English, you can get help at forum1529: Translation Assistance for Engineers
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. Galileo Galilei, Italian Physicist
