Overhead Crane - OSHA 125% Loading
Do you design crane runway beams to accommodate the 125% OSHA test loading for overhead cranes or do you allow the test load to rely on the safety factor?
I am having a difficult time understanding why a 20 ton crane would need to be designed for 25 tons.
I have not seen any crane design references (including AISC Steel Design Guide Series 7) that address the 125% test loading requirement.
Any documented information that indicates the crane support structure shall be designed for 125% of the rated crane load would be appreciated. Thanks!
RE: Overhead Crane - OSHA 125% Loading
I guess you are talking about following:
ASCE7-10 Crane load 4.9.3: vertical impact load, maximum wheel load for 2 type cranes need increase 25%. (page 16)
To answer your question I do not design for this. My reasoning is the intent is to test the crane by purposefully going into the safety factor a little bit during a safe/controlled test load. By increasing the design strength you aren't going into that safety factor and there may be a fault that goes undetected during the test.
Short answer, don't design for the 125% test load. But, as chrislaope said, design it for the impact factors as appropriate.
You'll also want to look at the gantry crane design specification; CMAA Specification 70. There are additional rules for deflection, straightness, and so on for runway beams of gantry cranes.
Maine Professional and Structural Engineer
American Concrete Industries
www.americanconcrete.com
The location of the 125% test load is not specified. Apply the 125% test load at midspan and the reactions at both ends are still very reasonable when compared to normal operating requirements. See this sketch:
www.SlideRuleEra.net
www.VacuumTubeEra.net
This load test is for the hoisting equipment and can be conducted anywhere along the support system, so you could specify where along the rail/runway the test should be conducted.
