magnetic coupling torque vs air gap
Hello All,
I'm new here and I hope I post this at the right place.
I need a way to determine how much torque can be delivered with a magnetic couple in relation to air gap (aluminum) has some one seen/know a simple solution for that? I have seen some papers and works in the field, but they are complex and before I delve into that I would like to find a simple answer.
Thanks.
Gil,
Thanks.
Gil,
RE: magnetic coupling torque vs air gap
Air is air and aluminum is aluminum. They are not the same.
http://www.teausa.net/Portals/0/uploads/Magnetic_c...
https://hal.inria.fr/hal-01164388/document
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
Can you post an arrangement sketch?
Walt
