ABAQUS_elements have missing property definitions problem
Hi all,
I am currently having a problem when running a thermal analysis. Basically I am getting an error saying that a number of "elements have missing property definitions. The elements have been identified in element set ErrElemMissingSection."
Does anybody know how to solve this?
If you could have a look at the files attached to check what the problem is that would be great.
Thank you!
RE: ABAQUS_elements have missing property definitions problem
hi dear
i had the same experince , i think , it is better you delete your material and make it again ,
or
check your section with its shape , i mean maybe you chose your shape , shell but it does not work , so you sould change it to solid.
i wish ,it works.
