Expansive soils
Expansive soils
Expansive soils
Are there any references for how to calculate forces/pressures exerted by expansive soils? I just curious to know how much non-expansive material may be required on top of an expansive clay in order to place a slab-on-grade. Or also check pressures exerted to a wall backfilled with expansive soils. Thanks!!
RE: Expansive soils
This is usually a site-specific, tested parameter. Generalizations won't do much for you.
Have the material tested.
RE: Expansive soils
Ron, I do have expansion potential values based on volume percentage from CBR testing. Can I use this info to calculate soil expansion forces? If so, how? I am not sure how to estimate these forces, but I am assuming that soil density may be involved.
Also, what are the site-specific tests that you are referring to?
RE: Expansive soils
Do a search for "expansive soil tests". There should be help there.
RE: Expansive soils
OG, I have been checking expansion potential based on CBR testing. There is an specific test for checking expansion potential, but do you think that expansion potential from CBT testing can be used as well?
RE: Expansive soils
OG thanks as always. Noted that minerology is very important to know. I will start my research about the minerology of my local clays.
RE: Expansive soils
hello
Why would you use a CBR test for such an issue ? i would recommend an oedometer test which may help get a rough estimate of the expansive pressure.
In any case , mineralogy is important as you can significantly improve the performance of the clay by adding chemical products .
RE: Expansive soils
CBR test results can directly give the swell potential (%) so I used it to have an idea of my soil conditions. My understanding is that swell potential can be verified using the consolidation test apparatus but our local operators are not familiar with this procedure. Fortunately, we do not have too many cases of expansive soils issues in my area, but happened to have a site where the CBR swell potential higher numbers (around 2%) and wanted to check further on this.
