Fatigue Modifying Factors in API 579 - FFS
Hi there.
For fatigue analysis procedure described in section B-1.5.3 of API 579 ¿In which of equations B1.30, B1.35, F.214 or F.215, fatigue modifying factors (surface finish factor, loading factor, etc.) must be applied?
Thanks!
Jairo
Thanks!
Jairo
RE: Fatigue Modifying Factors in API 579 - FFS
For an evaluation per B1.5.3, the Kf is applied to the stresses to calculate an effective equivalent stress, which is then compared to the S-N curve. The S-N curve is not modified.
Jack
There is a number of fatigue-related quantities that are not explicitly detailed, but are hidden in the S-N curves, much like the mean stress correction. The quantities that you refer to may fall under such a categorization.
