How to switch on the Drag and Drop option for NX10.
NX 10.0.1.4
I have a problem with opening the files using "drag and drop" philosophy and can't find the relevant option in the preferences to switch it on.
It doesn't work also when adding the component into the assembly.
At the same time, I have also NX 7.5.5.4 installed, where "drag and drop" works without problems.
Thanks in advance for help,
Łukasz
RE: How to switch on the Drag and Drop option for NX10.
In Customer defaults, you should be able to find it... just search in there for drag...
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
