Slab on grade & frost heave
What are some of the best ways to have a slab on grade and yet protect against frost heave?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Slab on grade & frost heave
The turn down at the perimeter helps, but the entire field of concrete only has a 6" barrier against the cold and will likely still freeze and heave.
A gravel pad is good, but to carry it 5'-0" below grade is a bit pricy.
Would it be possible to let it heave and provide flexible connections so that the heaving creates no problem?
BA
When I am working on a problem, I never think about beauty but when I have finished, if the solution is not beautiful, I know it is wrong.
-R. Buckminster Fuller
Mike McCann, PE, SE (WA)
A confused student is a good student.
Nathaniel P. Wilkerson, PE
www.medeek.com
BA
