NX10 center point of OLET
Hi
I am trying to export PCF file from mechanical piping assembly. But there is no center point for component with ISOGEN_COMPONENT_ID format OLET. All TEE components have these center points.
In OLET I define two fitting ports in center and top branch (see picture).
Does anyone know why could this happened? And what are the major feature in construction tree for center points calculation in PCF file?
Thank you
RE: NX10 center point of OLET
Found the answer.
To get center point exported by PCF plugging, it's necessary in "Qualify Part" mode create two types of port:
fixing port(center) and fitting port(branch)
Andrei
