Mixing small and large batteries
I'm trying to help a professional race car team with their battery and starter motor system. Being a race car weight is critical, but the ability to start the engine is even more important!
The onboard battery is a small lightweight 12v AGM battery with a 26 amphour rating. The "slave" battery (used only for static starting in the pits or garage) is a "big" lead acid one as used on a big engine pickup truck.
The team has suggested they connect these in series (instead of in parallel) to give 24v "to spin the starter motor better". Would it? My battery technology knowledge is limited - what happens to the small battery if we do this? Would it damage it?
The starter motor is rated at 1.4kW with 12v. Obviously one would not use 24v on a 12v motor in a street car expecting it to last 10 years - but starter motors on race cars are rebuilt or renewed every year and they always carry a spare.
RE: Mixing small and large batteries
Your question really doesn't make clear what problem you're trying to combat so we can help.
Does the "cart" battery start the engine without problems?
Keith Cress
Back in the old days, some cars used to be 6 volt systems. Some were converted to 12 volts. Based on what I've read, it wasn't uncommon to just run the 6-volt starter on 12 volts.
It's still not recommended. Can you find a better starter? Perhaps from a diesel version of the same engine?
So, while you might have doubled the voltage, you would have increased the parasitic resistance of the battery by 4x. I would do a complete and thorough review of your jumper cable and other resistances before messing with the voltage
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
Based on the discharge curves in the datasheet for the 26Ah battery, it might not even look like a battery at the discharge current required for a large starer motor.
TTFN
TTFN
What more needs to be said about the problem statement?
I would suggest measuring the voltage drop between the battery terminals and the starter motor terminals to see if cable and connector losses are significant. Connect the probes to the lead post on the battery and to the stud on the starter.
As others have stated, a small battery in series with the big one will only make thing worse. If larger cables won't help then you need a bigger battery (or two batteries of adequate size in series), or a more powerful starter motor. You could also consider an external booster battery for starting in the pits. It is pretty rare to need the starter motor during a race.
A great forum and some great replies - thank you again - Derek
I'd look for a better starter. My two diesels both draw well over 1,200A starting. Shockingly a replacement starter motor I recently installed was a geared drive one, very unlike the OEM one, and the motor was easily a quarter the size of the direct drive OEM unit. It spins the engine to almost idle speed.
I'd check around for starter hacks your formula group uses since someone has probably 'fixed' your issue already with a starter motor mod.
Keith Cress
Pricey, but effective.
What make of vehicle/engine are you working on?
What kind of starter? If you're not running a permanent magnet gear reduction starter then why not?
No ability to start on track will appear to be a great weight saving option until the first time the starter is needed on track and the car goes down laps trying to get it push started or towed to the pits.
If there is a starter mounted solenoid then there is most likely a coil in the solenoid connected between the "start" terminal and the motor terminal. I doubt this type of solenoid would work right with different system and start voltages. You'd be reversing the current in the coil which could cause the solenoid to drop out.
Also, do consider the weight of all the cable and connectors you use for a certain configuration, not just the battery.
