X70 Weld Qual Query
X70 Weld Qual Query
Hi
I have been given a Back to base metal repair using 625 Clad to look over for repairing X70. The PQR material certificate states X65 but the mechanical properties and chemistry meet X70. The PQR test results show results exceeding X70. Could this be acceptable if a new WPS is written or should I ask for a supplemental test using the parameters used on the X65 procedure
RE: X70 Weld Qual Query
Is impact testing required ?
X65 = P1 Gr 2 and X70 = P1 Gr 3.
Cheers,
DD
