Fillet in skecth does not snap to any feature
When I am in sketch mode and insert a fillet, the cursor does not snap to any curve or point in the sketch. This is quite frustrating as I don't necessary want to specify a radius for the fillet.
Is there a obvious reason for this to be do and is there a way around it?
Thanks in advance.
Thanks in advance.
Here's looking at you, looking at me, looking at you
RE: Fillet in skecth does not snap to any feature
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thank you very much, that is handy.
I however want to have even more control of where the 'control point' of the fillet is placed (not the fillet radius).
With this I mean that if you insert a fillet by hovering the mouse near the vertex inside the two edges and both edges get highlighted, if you then click MB1 you can drag the fillet to the size you want, but the mouse doesn't snap to any feature in the sketch, so the only way I see to accurately define the fillet is by specifying the radius, but in my case I am not sure what the radius should be.
Michael
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
That was exactly what I was looking for.
Michael
