Novel Client-Bypass Login
All,
unknowingly, i sure did make changes to pc.
pc system:  dell inspiron laptop using windows 2000 profesional edition, pentium III processor
i installed novell client software and now get a ctrl+alt+del message box to login into network and the pc is not connected to network.  i supplied win2000 adminstrator userid and password and not able to get past novell login message box.  i'm frustrated and even re-installed win2000pro thinking the novell client will be deleted, but not the case.  i've check for help on some web sites with not much luck.
does anyone know of a procedure or trick to get past the novel login message box so that i can delete novel client software from the pc?
thanks, -pmover
RE: Novel Client-Bypass Login
all,
i managed to boot pc in safe mode and manually delete the novell client software, then re-boot the pc without getting the logon prompt for netware.  then go through the process of "properly" removing the novell software.
-pmover
