vertical pump test
vertical pump test
what are the disadvantage of testing vertical pumps with short shaft length due to sump test depth limitation?
RE: vertical pump test
Also make sure the vendor has performed critical speed analysis (this is done on paper) to make sure you won't run into resonant frequency problems with the actual pump at actual job speeds. Also good to double check minimum submergence criteria will be met in actual sump.
