Concrete Design - Thermal
I am currently designing a concrete basin in staad (Approx 12m x 20m) and 4m in height. There is a very large range of temperature on the site it is to be constructed. I am going to use all the relevant codes and standards in order to take on board thermal cracking and keep crack width to a minimum for water retention. My question is, when setting up my staad model, do I need to add in the max temp +43 degrees and min Temp -40 degrees for axial elongation. As the basin is on piles, this would lead to a very large load and I don't think this is the correct approach? Could someone please help? Also, I have not applied the temp differences to the pile caps as these will be buried.
Tim
Tim
RE: Concrete Design - Thermal
To use the full range for thermal expansion would require that your concrete be placed and initially hardened at the extreme low temperature of your range....not likely.
