Vessel preservation
Vessel preservation
Gents,
We have vessel lined with Incoloy 825. We are going to remove from service for long time.
Can you advise requirement for preservation of vessel during long period of idle?
Appreciating your inputs in advance.
RE: Vessel preservation
Any vessel left closed for a long period will collect moisture. From the heating and cooling cycles each day eventually there will be condensation. And this water will contain whatever is in the local air. This will settle in low areas. If this is near a chemical plant or the coast you will end up with various acids and chlorides, and this will lead to pitting.
I will be highly appreciated if you advise me with ref. code for this procedure (if any).
