UPVC Pipes installation within concrete slab
Hi all, my issue for installing high pressure UPVC pipes within a reinforced concrete slab, the application is for discharge pipes for swimming pool, the pipes are supposed to be laid between to layers of the steel rod.
is it acceptable / safe for pipe, or there is any kind of precaution required ?
