Kewanee Boiler Manual Search
I would very appreciate if somebody can give me Web link where I can download information about Kewanee Boiler with the following characteristics:
Catalog #: H35600-6
HP: 600
Rating: 20085
Max Working Pressure: 170 lb
Heat surface: 3000 sq.ft.
All the search I performed gave me results for 150 or 200lb pressure, but not for 170. And, moreover, there were just different vendors and manufactures lists, but not the manuals.
Thank you beforehand
Catalog #: H35600-6
HP: 600
Rating: 20085
RE: Kewanee Boiler Manual Search
Inspectors 614-888-8320. They can send you a copy of the original data report for a small fee. You will need the Manufacturer,the National Board Number and the year of build. This will be stamped directly on the boiler shell,probably under the lagging.
