Linked bodies failing in NX7.5
I have a customer drawing that has linked bodies. These bodies have been moved so they can be used in an exploded view.
The file will open fine sometimes but other times some of the bodies will no longer be in the list and the drawing view will fail.
That same file can be opened again and be fine.
I can open and close the file back to back without doing anything to any connected file and it works sometimes and not other times.
There are no broken links, the linked bodies do not even show up. Not all the bodies, just a few of them. Like the ones that I need.....
What is happening and how can I fix it. This is a customer file so I am not at liberty to post the file.
thx
thx
RE: Linked bodies failing in NX7.5
Can you create a simplified "dummy" assembly that illustrates the problem and upload that?
www.nxjournaling.com
