Placing a Tabular Note in NX 8.5 Journal
In a drawing sheet,we have different views like Front View,Back view,Side view etc.(Total 6 views)..When I am using SpecifyScreenPosition to locate TabularNote in Drawing sheet other than views,then it is placed according to cursor location but when the tabularNote is placed at views,then the location is not same as cursor ..I hope you understand
I have written the following code to locate the position of Tabular Note in a drawing sheet:
Dim UserselectedPoint(2) As Double
UserselectedPoint = SelectScreenPoint()
If IsNothing(UserselectedPoint) Then
Return
End If
Dim TabularNotePos As New Point3d(UserselectedPoint(0), UserselectedPoint(1), UserselectedPoint(2))
The coordinates of the Drawing sheet are different from Drawing view:This is so called global and local coordinates concept.
Please help me in solving this..I need to locate my tabularNote correctly.
Return
End If
