Response Modification Factor for diaphragm attachment upgrade at existing tilt up structure?
We have a precast tilt up structure, seismic design category D. Would you use the current code to determine the R factor for seismic forces for roof diaphragm connections? Current ASCE 7-10 does not allow ordinary precast shear walls in design category D (R=3). The engineer on the project used R=4 for intermediate precast shear walls, but to me this seems un-conservative for an existing building pre-dating intermediate shear walls.
RE: Response Modification Factor for diaphragm attachment upgrade at existing tilt up structure?
What is the reasoning and scope of this "upgrade"?
Have you read ASCE 41?
"It is imperative Cunth doesn't get his hands on those codes."
