Name of the sensor
Name of the sensor
Hello to everybody,
I hope this is the correct section where to place this question.
I am planning to make a little automation to my home shutters and to know the specific position where the shutter is in every moment I found the detector that can view in the attachment.
Spite this, I am wishing to buy some of this rotating sensor, but i don't have any idea of its english name (it may sound likely roller arm to detect rolling shutter/Wheel operated detector for shutters...) may someone help me in the translation of this stuff? Internet did not helped me after a couple of hours of surfing...
How would you definetely call this sensor? How would you type it to found a seller over the Internet?
Thanks to everybody for any suggestion.
Andrea
Andrea
RE: Name of the sensor
Dan - Owner
http://www.Hi-TecDesigns.com
That one linked appears to be a big old potentiometer. Perhaps a modern tiny tilt sensor of the sort Arduio hobbiests use would be better in most regards. Tilt assumes horizontal blinds.
Adding to this with pulses coming from the sensor i can be more sure about the real movement of the shutter without any obstacle( if the shutter cannot move for any reason, lets jmagine a box left below i that s blocking it the motor will be overloaded till domething will be break. Better to know ghe movement status from real.
I Will post che whole Project detail once realized.
Main doubt is the English name of that kind of sensor...any suggest in how to find it over the web?
Could someone help me in finding the right translation to identify this device?
http://files.engineering.com/getfile.aspx?folder=3...
Thanks to everybody.
Andrea
It should be more a roller microswitch with pulses output? Going crazy to find out its name...
If you search for pancake encoder, you'll find a couple PCB-based devices: http://www.optical-encoders.eu/pancake-encoders.ht...
or search for optical encoders, in general.
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
