industrial chimney
industrial chimney
industrial chimney
Hi
Is that there is a code for calculating industrial chimney ( thickness calculating for example ) used in oil refineries , If yes wherein ????
RE: industrial chimney
Steel or masonry? If steel, then ASME STS-1.
Another question , how can I calculate the thickness of the chimney from the chimney vacuum pressure ???
And there is a table of standard values ​​of thickness as a function of the pressure
Your design will generally be driven by wind.
Is this a steel stack? If so, see ASME STS-1.
