Mahle WF series for Hot oil system
I'm commissioning a gas plant and for heat medium using therminol 66 by eastman company. the problem is being faced is that mahle wound type filter element elements were found decomposed even temperature was only 125^0c.
Thus anyone can explain why filter elements are decomposed even delta pressure against filter was only 30 psig.
10815L
10815L
RE: Mahle WF series for Hot oil system
Data sheet is saying these filter elements can operate upto 400^0c, in addition to this i heard tiny explosion at filter delta pressure 20 psig and temperature was 130^0c.
Hope you have more information for analysis.
10815l
Is there a mechanical warranty clause in the purchase order spec with this vendor ? - if so, they should fix this at no extra cost to your company.
Good luck,
Latexman
Technically, the glass is always full - 1/2 air and 1/2 water.
Elements fused like cotton, you can break it easily without any extra force applying.
10815l
