How to show in model that parts in assembly are welded? NX7.5 soon will be NX 10
How to show in assembly model that parts in assembly are welded?
1. make sub-assembly,
1. Make wave link of welded components,
2. Make "Bond" constrain between components,
4. Combination of options above?
5. ?
I am not aware how it works in NX 10 so I would appreciate info for NX 10 too, as I have to plan how to do it in future.
RE: How to show in model that parts in assembly are welded? NX7.5 soon will be NX 10
I would suggest to have a look at the weld assistant. It sounds like this is just what you are looking for...
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
special license required for weldments....
Sorry I did not mention that we do not have licence for weld assistant, that is why I have to use workaround, and why I am asking for help.
  1. Create Weld assembly
  2. Wave-link or Promote components to toplevel Weld assembly
  3. Unite Welded bodies
  4. Use edge from unite to create 3D (Sweep of Weld section) of weld..( for showing Weldgeometry on Drawing and perhaps weight management)
  5. Create Weld Reference set to hold Linked bodies
  6. In context of Weld Assembly set referencesets for components to empty (This will leave you with linked bodies only which imporves loadingspeed of your drawing)
  7. Create Drawing for Weld Assy using the Weld reference set
NX8.5.3 / TC9.1.2
HP Zbook15
Thank you nutace!
