Head drilled hole in socket head screw formula in hardware library
I am creaing hardware library for socket head screw having the condition
Drill 2 holes if screw size is 04 (.1120) and 06 (.1380)
Drill 6 holes if screw size 08 thru 16
I had inserted formula
SCREW_DRILL_HOLE_COUNT= IF(THD_MAJOR_DIA==.1120 || THD_MAJOR_DIA==.1380)1 ELSE 3. This formula works however drill holes not applicable on above screw size 16 and below size 04. What is the formula I have to use for this condition?
RE: Head drilled hole in socket head screw formula in hardware library
Assuming that you're going to use a 'Suppress by Expression' to remove the unwanted 'Screw Drill Holes', the logic statement would look like this (note that I only have information on number-size machine screws going up to #12, so in the formula I'm showing .XXXX as the major diameter of a #16 screw):
SUPPRESS_SCREW_DRILL_HOLE= IF(THD_MAJOR_DIA<.1120 || THD_MAJOR_DIA>.XXXX)0 ELSE 1
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thanks John
