Strengthen Concrete Ground Beam
Hi all,
I need your opinion and help. How do you strengthen concrete ground beam if they are already constructed?
Thank you for your help.
#LoveWins
RE: Strengthen Concrete Ground Beam
Reduce the span by adding a foundation at mid-span.
BA
Another possibility is to cast another beam alongside, if the load can be delivered to the beam, and further that the additional beam can be supported on the piles.
BAretired/hokie66,
Thank you for your suggestions! (:
#LoveWins
